Old 09-23-2015, 10:34 PM   #288 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by BabyDiesel View Post
Exciting news to hear!
Now would 35:1 AFRs still be possible, or should I aim for 20-25:1 since I won't haz boost at lower rpm?
If I were to use a turbo that made say 1-2 psi between 1400-2000 rpm and was waste gated at 5 psi max for the mid and upper rpm ranges, what would the possibilities be then? Would my drive (line?) pressure be too high above a certain rpm?
I was told that cylinder deactivation would not work on my car due to me not having a way to stop the intake valves from opening and closing, and it would hurt my BSFC is this truth???
I would aim for 20 to 25:1 A/F.
Nope 1 to 2 psi with the size engine you have won't work. You would have to extremely lean, above 40:1. Now this is based on the 4 to 6 hp needed.
Sorry but its the truth. To make your engine cylinder deactivation would take a crazy amount of change.
Keep in mind the engine is just a air pump. So when you increase your air flow
you can only do so much with lean burn and higher IAT to keep from having to add extra fuel. This becomes even more of a issue because now you want a low HP output from the cars aero improvement.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
MobilOne (11-13-2015)
