Old 09-25-2015, 02:02 AM   #1 (permalink)
oil pan 4
Amp draw before and after LED.
1978 to 1991 9th gen chevy/GMC suburban and pickups with the same lighting scheme.
OE running lights draw 3.75 amps.
OE brake lights draw an additional 3.5 amps.
OE halogen low beams soak up 10 amps.
At a stop light after dark sitting there with the brakes pressed the electrical system demands 17 amps.
That's a lot if you are trying to be out driving around with no alternator.
With a mix of mostly LEDs and some incandescent instrumentation and running lights it uses 2 amps (mostly due to OE dash lights I never changed over to LED and the front blinker/running light that I can not switch to LED or my blinkers wont blink)
LED brake lights added an additional 0.5 amps
LED head lights use 2.5 amps.
At a stop light after dark sitting there with brakes pressed the electrical system now demands only 5 amps.
12 amps makes a big difference.
Last edited by oil pan 4; 09-25-2015 at 04:47 PM.. Reason: After testing I found one 194 running light burned out, they draw 250ma
The Following 15 Users Say Thank You to oil pan 4 For This Useful Post:
BabyDiesel (09-25-2015), brucepick (09-25-2015), Daox (09-25-2015), Daschicken (09-27-2015), deejaaa (09-25-2015), j12piprius (01-18-2016), OG VX (09-25-2015), pgfpro (09-25-2015), RedDevil (09-25-2015), redpoint5 (09-26-2015), serialk11r (09-26-2015), spacemanspif (09-25-2015), ToddT58 (03-18-2016), Vman455 (09-25-2015), wdb (09-25-2015)
