Old 09-25-2015, 02:28 AM   #305 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by pearl62 View Post
I'm still not sure myself either... Maybe I will first just try it with Prius inverter, which is supposedly limited to just 20kW output from the voltage doubler. If it really is a bottleneck, I could maybe try a Lexus LS600H inverter, which is supposed to be good for 39.6kW?
Huh. That's interesting. I wonder why they rated the motor for such a high voltage, then made it's critical supply far short on the power output??
Maybe it has to do with when the boost is working - I mean, up to about 6000 rpm, the BEMF is less than 250Vrms. (2010 Prius motor data) Perhaps they're using the booster only if necessary for high speeds?
- E*clipse
