Normally the controller's 5 pin connector QEI supplies the +5v and ground for the signals. what is the ground of your 24v supply (that powers the encoder)? Is it the same ground that is used as the input of the How is it connected to the ground on the controller? is the +5v generated on the control board connected to the +5v generated by the voltage divider?
