Hersbird: Some limitations apply. At 15", there is only one LRR option for me: The General Tire HTS Grabber. The advantages are that it's a cheap tire that I could put on a cheap wheel, but the ride and handling characteristics are unremarkable, as you might expect with, well, cheap.
My bolt pattern is 5x139.7, which you won't find in later model wheels for this vehicle.
At 16" wheel size, the LRR tires won't carry enough load to suit me.
At 17" & 18" sizes, I get lots of options, ranging from great performance but heavy and expensive to much lighter and merely adequate performance wise.
I may still end up going with the cheapest / lightest LRR option at 15".
