Old 09-25-2015, 04:15 PM   #4 (permalink)
lasitter
OK: So I decided to keep it cheap & simple. I got wheels that were only 20 pounds each in 15x8, but which will carry up to 2600 pounds, matching the Grabber HTS LRR, @ 109T-XL/2271 pounds per tire and weight of 32lbs per tire.
The tire and wheel are cheap and available and the performance is adequate. They match the speedometer/odometer perfectly and I'm picking them up on Monday. The tread width is 7.2" vs 6.5" for my current Kumho Solus KR21, and the load carrying capacity is slightly greater.
