Old 09-25-2015, 05:27 PM   #297 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by BabyDiesel View Post
I could sliced one lifter per cylinder in half...
I have the blessing/curse of not having a rocker arm setup. The cam spins and pushes down directly on the lifter and valve.
Think Prius engine when you see/hear Atkinson cycle. Here is a decent definition:
Oh so you have to regrind the cam.
Atkinson uses slightly different timing for valve opening and closing events -- in particular, the intake valve stays open as the compression stroke begins. This difference results in increased fuel efficiency, but decreased peak power. It's common in hybrids because those are the most focused on efficiency, and the electric motors can compensate for the horsepower deficit.
I understand the concept just not to sure on the cam events etc.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
MobilOne (11-13-2015)
