Old 09-26-2015, 01:30 AM   #303 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by BabyDiesel View Post
Oh! My mistake I do not have to regrind the cam! What I can do as far as the single intake valve is either cut a lobe off or take the tappets out, according to Hardline. He has hypothesized that taking tappets out is one way to deactivate to a 2 cylinder.
Moving the timing belt around a gear tooth or 2 is even cheaper
This seems like a possible idea! An 11% increase in combustion efficiency sounds like a huge jump! Factor in the Atkinson cycle will provide more C.E., and you have quite the efficient engine.
How on earth would I keep the boost so low? Would I have the turbo wastegated at 2 psi? Big turbo?
Also, if my engine responds decently well to becoming a 1.0 2 cylinder, would this mean I could run more boost at low rpm? There's so many variables to consider!
All I know is for the time being I want to get the wideband installed and get lean burn working better than it has. I am seeing no increase in mpg so far
You wouldn't have to have the turbo wastegated at 2 psi and up to 6 psi. The proper choice in a turbo would only get you the low boost numbers, with out anything going through the gate.
With the low Cd it still looks like the you would be running in N/A even with a 1.0 L equivalent. This why i would run all four cylinders in a Atkinson cycle N/A and pull one tappet per cylinder to help with swirl. The when needed get into a mid-load and start making some boost in lean burn. This will accelerate the car up to speed and go back into light load steady state.
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
BabyDiesel (09-26-2015), MobilOne (11-13-2015)
