Originally Posted by thingstodo
A good criteria for a fun-to-drive car. My standards are a bit lower - I need to get to work and back home without getting run over by other drivers
Well, you don't have to make the end goal on day one. But it has to be modular enough to reach the goal without throwing away everything every time you upgrade it.
Motors can be upgraded. Batteries added to the pack without throwing away old stuff. BMS should be somewhat modular so it can be extended.
A 200kw controller would go a long way. And this one is really affordable - and the power stage can be upgraded.
I found a used Nissan Leaf motor (those are rated 80kw/110hp and 280nm) - for just over $2k. Somthing like that would be more than enough to get to work.
