Old 09-26-2015, 03:31 PM   #1 (permalink)
fearlessjoe
sunroof ... vent
thats proably a stupid title .....
this is my first real post on here... so hi
has anyone ever thought about .... i dont know how to describe it..... making air vents that run from a sunroof and or side window to out the back window or some kind of make shift 'vent hole'
so if you didnt have anyone in the back you could channel air to behind the car
allow my bad 2d ms paint job to ellaborate
the idea being the channel could be made of something like single ply sheet of plastic... carbon fiber if its fancy, so it could all unclick and be mounted flat to the inside off the roof for use of the back seats
that way the side peices can have a channel that the bendy top and bottom peices click into and the same for the side windows that could be rolled down for use as vents
you would have to have some kinda rear window replacement you could attach for use when there are people in the back or parked up
opinions
The Following User Says Thank You to fearlessjoe For This Useful Post:
aerohead (09-26-2015)
