Old 09-27-2015, 01:55 AM   #307 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by BabyDiesel View Post
I remember seeing your thread about excessive oil consumption with your truck. That seals the deal for me lol. You bring up a good point about intake flow. Everything is sized for a 2.0 I4. Dropping 2 cylinders for would make everything wayyy too big and flow would more than likely suffer.
I was reading your thread on d-series about your 64.8 mpg testing run that's what I want! Only better I will aim for reducing displacement through cam timing. My C.R. should be fine if you good with 9.5:1.
Were you running a Holset 351 off of a 5.9 Cummins on the Del Sol?
The Del Sol had a few different turbos. The Holset was the last one I tested.
The Del Sol had a terrible Cd and I was going to do a full boat tail but ended up selling it to buy my new house. Its funny how life gets in the way.lol
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
MobilOne (11-13-2015)
