Old 09-27-2015, 08:52 PM   #3 (permalink)
cyclopathic
Originally Posted by digital rules View Post
It's likely a combination of the new tires, a less rolling resistant tire & the winter fuel blend.
Higher pressures will always result in improved rolling resistance, especially between 30-50 psi.
Well this is a 2000lbs car. 50psi would be equivalent of 75psi in 3000lbs car, correct?
I am seeing MPG improvement after dropping pressure down under 40psi
