Old 09-28-2015, 12:31 PM   #310 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by BabyDiesel View Post
I read through your thread here and at d series, incredible! I really wish the boat tail would have been tested, it looked like a winner!
I have been thinking about turbos for the Escort. I decided that I wanted to keep it in the family though, so my first thought was a Garret GT3782 off of a 6.0 Powerstroke
Here are the stats from the ford-trucks forum.
compressor side:
IND whl = 59.10mm
EXD whl = 82.00mm
Trim = 52
A/R = 0.54
turbine side:
Whl dia = 72.50
Trim = 84
A/R = 1.12
Let me know if this is even a possible choice.
The converstation is everywhere Hardline! I am seeing that the asymmetric cam is the way to go. I will probably have to get a custom cam from Crower, but that is fine by me.
I will not cut and lifters either, that sounds scary! I wasn't going to do it, just joking around with a way to achieve what Russell (pgfpro) has.
With the Cd you have now that would be a good choice with a 2.0 L engine, if you somehow get it down to a 1.0 L then I would go much smaller.
If you drop your Cd down from what it is a sub-0.20 Cd then you will just use the turbo gain some HP when not in lean burn. So in this case i would run a much smaller turbo.
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
BabyDiesel (09-29-2015), MobilOne (11-13-2015)
