Old 09-28-2015, 06:04 PM   #56 (permalink)
S Keith
120V on an 84 cell pack would be 1.43V/cell. The IMA pack probably only sees that voltage when it's near max SoC and charging at a high current. I expect the BCM is freaking out about high voltage when there is no charging. Can you just pull or bypass 1-2 of the LiFePO4 cells?
