Old 09-28-2015, 09:49 PM   #21 (permalink)
bobdbilder
bobdbilder's Avatar
Knight - '03 Proton Waja
90 day: 37.15 mpg (US)
Whoopee - '01 Proton Wira 1.3 Aeroback
90 day: 38.69 mpg (US)
Originally Posted by vibrating_cake View Post
Isn't the opposite true about the sealing at the windscreen side of the hood? Taking that off would try venting bonnet heat into a high pressure zone, which would effectively act as an auxiliary air intake into the bonnet that bypasses the radiator?
Hot air has high pressure too. A temperature difference of 55deg C (100 deg F) gives about 18% increase in pressure. As per the picture, you would think that its easy for hot air to flow down. Rather, the air stagnates inside the engine bay, which can cause a drop in differential pressure across the rad. I would say that air leaks out to the back rather than being drawn out. I do not think that ecomodders would drive fast enough to have high aerodynamic pressure to force the hot air back in. One would need to travel beyond 90km/h which isn't very eco anyways.
See also http://www.autospeed.com/cms/A_113157/article.html Unfortunately that article did not say what pressure that sensor is supposed to trigger, but you get the general idea.
Last edited by bobdbilder; 09-28-2015 at 10:31 PM.. Reason: Added reference to Autospeed and Pressure difference due to temperature.
