Old 09-29-2015, 02:23 PM   #2103 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by thingstodo View Post
Cool.
I get a warning when I program with the PICkit 3 - the hex file loads with no errors, but when I verify there is a mismatch at some address. I'll check when I get home.
Thanks a bunch - I remember you were having connectivity problems; hopefully we can all learn from this.
2.86V on a board that uses 5V sounds like a problem - it's too close to 2.5V and not close enough to 3.3V.
Yes, that does seem weird, like it's pulled down or something. The supply pins (21, 40) measure about 5V. I think the MCLR pin was 5V when not plugged into the debugger. I'll double check that.
I did not go through the PICkit 3 documentation. When I plugged it in, it worked, so the manual sits unread.
Here's the manual http://ww1.microchip.com/downloads/e...Doc/51795B.pdf
Page 20 shows a typical connection. It looks like a 4K7 to 10K0 resistor is typical - no capacitor.
Yes - and on page 21 they explicitly say NOT to have a capacitor from MCLR to ground. Does your board have one? I guess it would be pretty easy to remove it.
Thanks again for your help and suggestions!
- E*clipse
The Following User Says Thank You to e*clipse For This Useful Post:
MPaulHolmes (09-29-2015)
