Originally Posted by MPaulHolmes
Hey! We could have a contest to see which spins the motor post faster. The one that spins it the fastest is making better use of the fixed Id and Iq!
First, we need to determine your motor's stator and rotor inductance, and a stator coil resistance. In my case, it works fine to just use the same rotor inductance as stator inductance. To figure out the stator inductance, we have to run a test and measure the offset of 2 waveforms. I'll set it up, and make sure it's working on my end before sending it over to you so you don't get stuck with a crappy hex file.
Looking forward to it! Once the sensorless code is spinning the motor, I've GOT to get some video posted!
