Fills in my 99 HX can vary significantly, depending on the level of 'tilt' at the pump. If the car is pitched forward, more gas flows into the tank. I've learned to position the car with all four tires on the concrete pad.
Originally Posted by Donahue
Well, after my last fill up, the tank took more than usual, and I was hoping that the machine just clicked off later, and that it would average out with the next tank. I'm halfway through that tank, and either that's the case or this will be my best tank by far. My previous few have been around 440 miles, and this one is just hitting half tank at almost 300 miles.
