Originally Posted by Cd
What aboat this one :
Nearly everything is possible when the pockets are deep enough. Maybe some geek could attempt to make the the setup of a Lexus LS600h work into that rig. Not exactly Prius guts, but still based on the HSD
Or the setup from that hybrid Hino truck, as it's more dimensioned to a higher load factor. As for 4WD, one could either try to couple the HSD to the Hummer's stock transfer case or to try repurposing that all-electric differential for FWD.
