I'm glad you found an acceptable route. Even the smallest changes can make a difference. Like taking a cut through to avoid a busy intersection.
One of the great things about an ebike is you don't care too much if it's a little longer distance. Often times I wished I had a longer commute while on my ebike, it can be so enjoyable.
