Old 10-04-2015, 11:57 AM   #24 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by BabyDiesel View Post
If you flip it upside down, shouldn't the piece of flex pipe be able to connect?? The WAI pipe would be around the cat then from the looks of it.
You mean like this?
Then yes, the HAI is pointing down, but away from the engine
The only way to rotate is around the end which goes to the air filter, as that cannot really be moved to far. The CAI can be anywhere in the front, the HAI has to be coming from the exhaust manifold.
I removed a piece of the stock intake and roughly fit the t-stat WAI in its place:
Not bad. The engine side will need a rubber adaptor, the CAI nozzle may be moved a few cm, but the HAI will get chopped. I have to devise a metal ending that will bolt to the manifold.
Here are the insides:
Originally Posted by gafhj View Post
Do you think that installing such intake in a car with LPG is a good idea?
I am not familiar with how different the combustion process of LPG is (compared to petrol), but I assume that it would benefit from warmer intake air. And the reason a t-stat WAI is better than a straight hot air intake is that the air is not too hot, so knocking is not a problem.
ID:	18837   Click image for larger version
ID:	18838   Click image for larger version
ID:	18839   Click image for larger version
