Old 10-04-2015, 05:28 PM   #27 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by cyclopathic View Post
For example on LRR tires Bridgestone or Michelin use special more flexible rubber compound in sidewalls, and probably best LRR tires in US market Michelin Energy Savers have the thinnest sidewalls I've seen.
The EU Energy Savers will still roll noticeably lighter @ higher pressure.
Before joining ecomodder, I originally started increasing tyre pressure to cure or reduce wallowing and tram lining effects due to too low OEM pressure recommendations.
