Old 07-31-2008, 11:11 AM   #12 (permalink)
klrv6
Sandstone Princess - '99 Chevy Sububan LT
90 day: 21.04 mpg (US)
Joe - '02 Nissan sentra XE
90 day: 43.9 mpg (US)
Regal - '03 buick Regal LS
90 day: 33.85 mpg (US)
Originally Posted by ATaylorRacing View Post
You all need to be made aware that synthetic blends might only be 20% synthetic! You can get the same or better results bt using a qt of full synthetic and the remainder as regular oil.
I did this in my old Sentra, two quarts good dino oil and two quarts mobil1 (before they changed the formula).
If you guys are running synthetic, be aware they aren't the same. Most store bought synthetics are base3 stock and provide a little more benfit than dino oil. Things like Mobil1 EP are made from base4 stock and are what most people have always thought synthetics to be. I run mbile1 EP in my Sentra and grand national. The sentra because it turns at 3500rpm for two hours at a time and the grand national because the oil won't coke in the turbo when the engine is shut off and because of the zinc issue ataylorracing pointed out.
