Old 10-05-2015, 03:16 PM   #27 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
Lots of negative camber does help in cornering because the car puts all the weight on the outside and actually ends up with even camber in a hard corner. It make the outside tires way off but there isn't much weight on those tires. A circle car that only turns one way can be set up with negative on one side and positive on the other but a car that has to turn right and left will just run negative camber all around.
