Old 10-05-2015, 09:27 PM   #2134 (permalink)
e*clipse
Permanent Apprentice
Ok, now the blinky light is under control of the throttle.
So, I guess I have a good enough handle on things to do some useful work.
What do think about having a stripped-down "base" code that works with the current hardware. This idea came as I thought about stripping "sensorless.c" down to a "senseless.c" This is to assist my little noggin' in seeing the big picture.
This code would put out a sinusoidal PWM signal and measure current and throttle position. Perhaps other features, like contactor control, and other AtoD measurements could be built into this core.
It would be considered a solid foundation on which to build features like FOC and sensorless control. The base sinusoidal output would use a look-up sin table, with the frequency set in a volts/hz mode.
Hopefully I haven't suggested anything new here - it seems to be operating a little bit like this even under the newest sensorless code.
The new features, like sensorless control could be added as either code within the main or maybe sub-programs in a build.
This might facilitate programming different options, like sensorless code, encoder input, resolver input, FOC for asynchronous motors, FOC for synchronous motors, etc etc...
In fact, if things were done well, a "build" would just have the useful parts for that application. This might save computer time/memory.
Thoughts?
- E*clipse
The Following User Says Thank You to e*clipse For This Useful Post:
MPaulHolmes (10-06-2015)
