Old 10-06-2015, 07:02 AM   #17 (permalink)
2000mc
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Originally Posted by spacemanspif View Post
Today I went to a used tire place to have my rears rebalanced. When they pulled the rear passenger one off, the inside trad was showing steel sticking out.
Final specs on my alignment are kinda crappy but "within spec" so they wouldn't tighten up the adjustments.
Camber: FL: -0.2*, FR: -0.7*, RL: -1.3*, RR: -1.7*
Caster: FL: 2.6*, FR: 2.4*
Toe: FL: 0.02*, FR: 0.04*, RL: 0.21*, RR: 0.14*
Total Toe: Front: 0.06*, Rear: 0.35.
Print out says the FL toe was -0.19* and FR toe was 0.32* can't say the car pulled or anything and until I pump up my tires I can't really compare my usual coasting distances in my commute but that will be handled shortly.
the initial front toe measurement may look like that because the steering wheel was most likely not carefully centered before saving the before measurements, I wouldn't read into it beyond total toe of the before
I'm not really sure how total toe applies and works on a car but I'm pretty peeved the rear left being out so close to the 0.36*spec and the right side being closer to the 0.00* spec. I feel like they should have at least dialed the left in closer to the right but no, they are "within spec" and were left alone.
If the table at Alignment & Suspension Specs: Ford Focus is correct, total toe is near perfect, and I wouldn't be worried about the left to right imbalance. I think the effect would be your car dogtracking by .03* which I think would be undetectable by any other means.
I'm also annoyed with the rear camber specs and the fact that both are pretty negative and the right rear is at -1.7* and spec is -1.8*.
and this is the problem to me. I don't think it's a coincidence the tire with steel sticking out, was also on the corner with the camber on the edge of tolerances. Alignment & Suspension Specs: Ford Focus Says the spec for rear camber is -1.00* +/- .75* as this relates to my previous post, I would request rear camber set between -1.00 to -.25* and consider a range of -1.75 to -1.00* typical tire eating focus range. Even if the shop you were at is unwilling, I would find a shop that would be willing to make this happen
The Following User Says Thank You to 2000mc For This Useful Post:
spacemanspif (10-06-2015)
