Old 10-08-2015, 06:14 PM   #2150 (permalink)
e*clipse
Permanent Apprentice
[QUOTE=thingstodo;495883]For the cheap and easy solution, are the targets glued to the motor shaft? Is there a machined or perhaps an off-the-shelf ring slid over the shaft that has 3 or more targets? It would seem easier to keep a ring balanced than to glue targets perfectly on a round shaft ...[/QUOTE
In some ways my perspective may be clouded by my shop. You're right - gluing magnets around a shaft would probably not work.
Do you have any access to a lathe, maybe through work?
If you did have a ring with magnets, do you have access to the shaft?
I'm just thinking aloud; I think it would be a reasonable thing to make. I have made a quadrature encoder wheel for a test. However, it's probably much easier to get the encoder working on your existing motor.
- E*clipse
