Old 10-08-2015, 08:46 PM   #2153 (permalink)
Piotrsko
I myself would use a round target 1/2" thick in aluminum and drill / tap holes for steel hex head bolts where you need pulses. Drilling through gets you 180 degree apart holes.
Because its aluminum you could use self tapping bolts. If you need more "on" time just add steel washers under bolt head.
Btw: most sensors want to see 1/32 to 3/32 gap closer is better.
Flywheel sensor installs are pretty easy using drill and tap trick above. Really accurate too.
The Following 3 Users Say Thank You to Piotrsko For This Useful Post:
e*clipse (10-08-2015), MPaulHolmes (10-08-2015), thingstodo (10-09-2015)
