Old 10-11-2015, 05:36 AM   #29 (permalink)
HowGudAmI
HowGudAmI's Avatar
Clio - '03 Renault Clio 1.5dCi
90 day: 48.94 mpg (US)
Thanks for the replies everybody .
Originally Posted by seifrob View Post
Hi, i am just joining in, as it looks like we have cars with same engine. (although I was never able to get as good tank as you). I am looking forward to see your progress, all good advices have already been posted before. Maybe one: Buy an OBD2 plug and install Torque Pro into your phone, or get any other instant MPG readout. It helps a lot. If you will discover how DFCO work in this engine, let us know please. From my observations it seems it kicks in only in 1500 to 2000 rpm area and under that ECU puts fuel to help engine running.
Mine has the K9K 702 - which one is yours? I see your car is a lot newer than mine.
I have an OBD2 plug and Torque Pro already - though the MPG figures it gives do not seem to be right - it tends to show low 60's (Imp/UK) for economy on the motorway - but I must be getting more than that based on my actual tank averages. However, just using the adjustment won't work because it seems to be accurate to what I would expect in town driving situations.
I will see if the fuel flow meter (or something similar) works so that I can use it to work out DFCO and will post my results up.
