Old 10-13-2015, 11:10 AM   #30 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I'm not worried about the legality of this modification (someone else brought that up originally). The setup I was running before (drop-in LED bulbs) was blatantly illegal, as are all the plug-and-play LED and HID kits out there; if this is illegal, it's only on a technicality, and I very much doubt I will get hassled for it. Plus, with the better beam pattern, distance, output, and cutoff, this will be safer while using less power.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
deejaaa (10-13-2015)
