Old 10-14-2015, 02:47 AM   #33 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
UPDATE: Done!
Leveled them out at 25 feet:
The difference between these and the drop-in LEDs is amazing. Where the latter had no distance and put out almost as much light above the cutoff (through the "squirrel finder") as below it, these have a nice, sharp cutoff (thanks to the TSX-R lenses) with a bit of color, and even pattern with lots of output below it. Distance is excellent, and width seems to be pretty good too. I'm glad now I didn't bother with the quads, as that would have been overkill. And the best part is: 22W total power consumption!
If you're looking to lower headlight power usage, this is the way to do it. Two OEM projectors cost $125-$130, a few bolts and washers are a couple bucks, and the lenses--which don't have to be replaced--were $10 B-stock closeouts. So, all in these aren't much more than the cost of drop-in LED bulbs.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 4 Users Say Thank You to Vman455 For This Useful Post:
Daox (01-05-2016), deejaaa (10-14-2015), OG VX (10-14-2015), redpoint5 (10-14-2015)
