Old 10-14-2015, 03:14 AM   #922 (permalink)
bikeprof
Wannabe hyper..., miler !
bikeprof's Avatar
White Variant - '96 Volkswagen Passat TDI ~ GLS- 4 Cyl
Minivan - '96 Chrysler handicap IMS built LXI
Insight - '10 Honda Insight EX
THAT'S the way to do it properly! Bump from a higher gear, then shift to the proper one for the speeding up...
Using much higher gear lets the engine have less retarding/slowing when the "bump" is done...
My three cents!
Two normal ones plus the extra one I've saved learning how to HYPERMILING
Originally Posted by cowmeat View Post
Lol, you know it!
Thanks for the heads up, you were one hundred percent correct, and I'd have never thought to even try it.
I now bump start in fifth all the way down to 5 mph, then switch straight into the correct gear (or neutral at a stop sign), and it's waaaaayyy smoother!
The Following User Says Thank You to bikeprof For This Useful Post:
freebeard (10-14-2015)
