Paul - quick question regarding all the non time critical AtoD's.
Where in the code do you get these non-critical values? I'm lost...
Is this connected to this structure?
Code:
volatile realtime_data_type RTData = {0,0,0,0,0,0,0,0,0,0,0,0,0};
and this function?
If so, it's not called in code.
Code:
void FetchRTData() {
Is this assigned semi-automatically? Maybe through this?
Code:
RTData.throttle = throttle;
Or does this merely put a variable in an array structure?
*****edit*****
I've found some "normal code" in a large block of commented out code. Are you just not looking at throttle and temperature right now during sensorless testing??
I've done lots of DSPic AtoD, and I'm very confused...
Thanks for any enlightenment!
E*clipse
