Old 10-14-2015, 06:34 PM   #158 (permalink)
aerohead
Zeppelins
Originally Posted by orengomotors View Post
ok, so pointed nose is kind of sears-haack and is for a very very fast vehicle.
so every of the zeppelin shapes would serve, and i need to find what of them fit better the chasis, this is ok?
Yes,the pointed noses are for 250-mph and above.(409 km/h+)
If you want to do a 'tank' body based upon the airships it IS okay.
Remember, that you can essentially remove any of the constant-velocity,cylindrical center section to get the length you need.
You can also take liberties with the nose.
The only thing you can't negotiate is the tail.This is where most of the drag will come from if you get it wrong.
