Old 10-16-2015, 12:12 AM   #10 (permalink)
oil pan 4
I got the hydraulic power unit in early.
The motor has disastrous duty cycle, up to 1 minute on 3 to 4 minutes off. Which sux.
The pump uses size -4 ORB, -4 SAE, -4 straight cut O-ring.
The power steering box should use 18x1.5mm O-ring sealed.
To connect the pump to the steering box I ordered an 18x1.5mm to -6AN adaptor and a -4 ORB to -6AN adaptor.
