Old 10-17-2015, 02:58 PM   #52 (permalink)
aerohead
how much?
I posted that to show how much my thinking has changed since hanging around here (but didn't say so, sorry). Water might make a rooster tail but air not so much.
How much divergence is too much? A trumpet bell runs out to 90° axially. I thought they couple to the ambient air most efficiently.
For pipes and ducts the optimum angle for a conical diverging section depends on the k-factor (smoothness) of the boundary walls.But the drag minimums are at the 6-8 degrees range.
For a diffuser,there is a overall drag reduction with angles up to 11-degrees,but the minimums are at 2.8-degrees,to 4-degrees,depending on where the up-sweep begins.
Laterally,against the sidewall of the wheel fairing,I suspect that you'd mirror that angle,otherwise you'd have an asymmetrical pressure rise leading to vortice formation.
On the drive here this morning,the Denton High Marching Band was crossing the street in front of me.I was watching the horn bells.I'm not an acoustics guy,but my thoughts went to a reversed-ear.
Our ears concentrate sound into the ear passage.
The bell on the horns may reverse this to 'broadcast' the sound pressure waves.Purely an acoustic,sonic wave function,rather than aerodynamic function.
BamZipPow (10-17-2015), freebeard (10-18-2015)
