Originally Posted by aerohead
*You want 'fish' proportions with the body,with the overall body width within the first 1/3rd of body length,so I'd lean towards the lower image.But drop the nose down to level with an airdam.(I have an image I'll try and get scanned into Photobucket today and post for you).
*The diffuser should begin as forward on the body as you can make it.You don't have an axle inside there,so you may have an advantage there.
*Looking from above,the nose should be a semi-circle.
*Looking from above,the headrest/rollbar should be wing-shaped,and as long as the rule book will allow.
*If you can't enclose the cockpit,do a half-bubble canopy as close to your head as you can get.Integrate it into the roll bar as best you can
Hi aerohead!
looking forward to seeing that image,
ok, so the bottom will be flat until the tube chasis ends, and from there it will be a diffuser, is that what you meant?
I will close the cockpit.
