The teardrop shape has it's widest section ahead of the midpoint. It's generally a 30/70 split. That means you can sort of bury the front suspension, but the body needs to taper before it gets to the rear wheels, which is a problem.
thank you! i understand it now.
so the nose has to be rounded?
the nissan delta wing nose is poorly designed?
