The EPA rating might only be 30 mpg but I bet most drivers beat that. The 1500 Ram is only rated at 28 mpg but normal people are well into the 30's. Add some ecomodder tricks to the list and I bet you could beat 35 pretty easy. At least for now diesel cost less then unlead here. The problem is it is over $30,000, as is the Ram even a year old used is over $30k.
