Old 10-21-2015, 01:09 PM   #5 (permalink)
MobilOne
While you have that meter in use; check to see if you measure any voltage between the actual battery post sand the battery cable connectors. You should measure zero volts here. I have found this connection to have a hard black surface on the post and the inside of the cable connector. The black surface was so hard I had to use a rat tail file to clean the surfaces. A wire brush was not strong enough.
