Long time no update. I've just been driving the car 120 miles/day and haven't had much time to think/work on it. Last week as I turned onto a road I saw what looked like a factory air dam, I think it was off a GM car or crossover because I think it is supposed to sweep under the car. I mounted it up-side-down using factory bolts but had to drill and bolt/nut through the bumper on the ends since it doesn't reach the end of the bumper cover. I don't think it looks too bad and am thinking about extending it with gutter guard (or anything else flat) but I'll let you guys decide.
I also filled the gap under the headlights with some foam tape. This is the same foam tape I used to try and fill the gap Focus-AK mentioned in the above post, but the gap is so damn big that the foam did nothing.
Thanks for looking
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
