Old 10-23-2015, 11:38 PM   #2234 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by e*clipse View Post
- integrating boost inductor would be an issue. How about externally, with some plugs or maybe vertically, underneath the bus capacitor?
How are you planning to mount your controller?
Why do I ask? If it is very close to the motor, mounting the inductor between the motor and the controller allows using the motor as a heat sink for both the controller and the inductor.
Hmm. The controller likely wants to be MUCH cooler than the motor needs to be. Perhaps the controller can be the heat sink? But it makes more sense to have the motor tightly coupled to the motor casing ... and the inductor kinda pasted onto the side of the motor casing?
As usual, this would likely cause some noise to interfere with the operation of the controller.
The Following 2 Users Say Thank You to thingstodo For This Useful Post:
e*clipse (10-24-2015), MPaulHolmes (10-23-2015)
