Old 10-24-2015, 03:57 AM   #2237 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by MPaulHolmes View Post
The 3 boards I'm doing are meant for ghetto cheap "put it together yourself in the jungle with only a hand drill". The schematic would basically be the same though. Just stick the components in different spots on a circular driver board and control board.
EDIT: They don't yet exist in real life. JUst on the the computer, so I can't send it up to you, thingstodo. I wish it was done!
Yea, this certainly doens't meet those specs - LOL! The primary goal in this case is something light and small, since I will need 4 of them.
So - some quickee measurements - The new designs circuit board is about 265mm in diameter. That works out to about 85 square inches, minus the current sensors, etc.
The rev 2 revolt board is about 40 sq. in. So, there should be enough room for a boost stage!
- E*clipse
The Following User Says Thank You to e*clipse For This Useful Post:
MPaulHolmes (10-24-2015)
