vskid3, the gap filler on the front wouldn't have to be much different that what you did in the back.
BabyDiesel here is what I used from Lowes to stop the flaps on my skirt.
![](http://ecomodder.com/forum/member-kafer65-albums-pics-picture7023-aluminum-used-hold-skirt-away-wheels.jpg)
Its slotted and you can see in the picture on it that its slightly folded which gives you the ability to bow it for clearance and retain rigidity. I mounted it on the bottom of the skirt so the folded part tapers back toward the tire. Everything is nice and tight and slender in its cross section.
