Originally Posted by Cd
I guess the XJ-220 vs VW Fox was actually a poor example, because I didn't factor in downforce.
What I meant to compare was the shape of the vehicle.
So let me compare that VW Fox with the MX-3 . The VW Fox was certainly not designed for downforce !
You would think the MX-3 would be sleeker, right ?
VW Fox point 31 Mazda MX-3 point 32 .
Again,the VW (I believe) has the longer aft-body.It's aft-body aspect ratio is greater.This is the critical factor for low drag.This was at the central core of Kamm's/Fachsenfeld's research at the FKFS.
