Old 10-24-2015, 01:07 PM   #10 (permalink)
aerohead
Jag vs F-150
Originally Posted by Cd View Post
Yes. In fact, I had read that the original design was tested at point 32. Later versions were point 36 !
"A number of small design changes for the body were tested in the wind tunnel; the final version had a drag coefficient of 0.36 with downforce of 3,000 lb (1,400 kg) at 200 mph (320 km/h).[28][41] The XJ220 was one of the first production cars to intentionally use underbody airflow and the venturi effect to generate downforce.[41][42]"
So that means that this car :
has the same drag as this truck ( both at point 36 ) :
We pay dearly for high speed stability.
Common sense is an inverse-square relationship to disposable income.Double your income and you get four times as stupid!
