Old 10-24-2015, 08:48 PM   #42 (permalink)
CFECO
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
OK, today I picked up my second donor MX Bike, for my Electric Side by side UTV. With the photos perhaps everyone can get a better idea of what I have in mind. The upper portions of the frames will be removed, the two frames connected with tubing, the forks attached together with a tie rod and a steering box, the seats will go above the swing arm pivots, the bottom tubes lengthened some and triangulated, the rear shocks relocated to the top of the swing-arms, and attached at the top to a bar across the back of the seats.
What I need is a small differential, which will be between the swing-arms, with the motor to the rear and the chains driving off the axles of the diff. Anyone have any Ideas on a good, strong, light, diff? Ive been looking at a Yamaha Rhino diff, the problem is the rear is a spool so would tend to go straight, and the front Rhino diff is a bevel gear not hypoid, so I worry about the strength with the high torque of the electric motor. Anyway, the chassis progress will continue while the "Minor Details" are worked out.
ID:	18950   Click image for larger version
ID:	18951   Click image for larger version
