The dual mass flywheel will explode if it hasn't already at least once. Both of mine were replaced with single mass and survived just fine when I did timing belts. Hopefully, the fuel pump won't gall and take a dump on the fuel system, but honestly though, if he's doing that much driving it may be ok for a few years since its a Golf.
OTOH, seems that the German made two doors may be a bit better. I haven't been there in a while but TDIclub is loaded with fixes that will give you a heads up on any eventualities that might arise. God help you!
