Old 10-24-2015, 09:43 PM   #10 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I've messed about with this kind of alt on UFI and here's what I found:
1. The alternator monitors charge acceptance, not just voltage (voltage can't tell you much frankly). If you fit a LiFe or supercap, you'll change charge acceptance and the alternator will become confused. I often had to stop and reset the system as it would go into safe mode (constant 14.0V). S/S was never going to work as again, charge acceptance was too high as judged by the ECU.
2. Disconnecting the alt is all but pointless. Essentially (assuming you have a serpentine belt), it's already free spinning much of the time so removing it and fitting an idler pulley won't help.
3. Charge the battery every night. You'll get a solid 5% gain as essentially the alt is now off because the battery is full. It will still ramp up on overrun for some free charging.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
MobilOne (10-25-2015)
