Originally Posted by ksa8907
Id put that on the under side of the hood and any other exposed metal in the engine bay. An under engine cover will help a lot too.
I'd do the same but first if you have any to spare cut out a bit and stick it to the underside of the hood to see how it handles the heat. It'd probably be better to find out a 1sq inch tab melts or catches fire than have the whole hood burst into flames.
